Home > General > RRS TDV8 Front Noise - Chirp/squeal/Rattle
Chilly07
Australia
Hi All,
I have a TDV8. 2008. Couple of days ago it start chirping/rattle/squeal type noise form the front Drivers side. (O/S/F).
Appreciate advise.
Thank you
Chilly
Post #483949 Mon Jan 04 2016 7:05am
Camelrock
If you mean O/S/F wheel then I would remove wheel and pads, loose mud shield etc. I assume you've tried driving back and forth in case it's a trapped stone. Does the noise go off if you apply the brakes ? 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #483962 Mon Jan 04 2016 11:10am
Chilly07
Australia
Thought it might be a stone but cannot remove by driving.
Tried applying brakes while driving and still happens.
In process of ordering new pads....mine are low. Will then look deeper into noise
Thanks,
Chilly
Post #483963 Mon Jan 04 2016 11:13am
l200jmc
Has same issue, turned out to be a stone In-between disc and guard. I just pulled the guard back and it came out. Hope you get this sorted
Post #484229 Thu Jan 07 2016 4:37pm
Chilly07
Australia
Hi,
A bit moe information.
I have jacked the car up under the spring. It sounds like air is coming out at the top.
No stone in the discs!!
Thanks,
Chilly
Post #484333 Sat Jan 09 2016 2:18am
Chilly07
Australia
Hi,
Have removed air strut/spring. It was leaking from the top. New strut/spring and all good.
Now on to the Dynamic Response oil leak!!!
Post #484873 Fri Jan 15 2016 10:49pm
