Home > General > RRS TDV8 Front Noise - Chirp/squeal/Rattle |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
If you mean O/S/F wheel then I would remove wheel and pads, loose mud shield etc. I assume you've tried driving back and forth in case it's a trapped stone. Does the noise go off if you apply the brakes ? 2008 G4 RRSport TDV8 current
Mon Jan 04 2016 10:10am |
Chilly07 Member Since: 25 Dec 2015 Location: Central Coast, NSW Posts: 24 |
Thought it might be a stone but cannot remove by driving.
Mon Jan 04 2016 10:13am |
l200jmc Member Since: 07 Mar 2015 Location: North East Posts: 16 |
Has same issue, turned out to be a stone In-between disc and guard. I just pulled the guard back and it came out. Hope you get this sorted |
Thu Jan 07 2016 3:37pm |
Sat Jan 09 2016 1:18am |
Fri Jan 15 2016 9:49pm |
