![]() | Home > General > rear tail gate struts handed info |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
![]() ![]() L/H BLUE R/H RED Cheers Col Last edited by Col on Sun Jan 03 2016 12:27am. Edited 2 times in total |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
Just triple checked and mine seem to be wrong - that won't be helping 2016 Black SDV8 Autobiography
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
The confusion is LH RH |
O/S and N/S are generally taken from sitting in Drivers Seat or Stood at Rear of Vehicle so Driver side R/H, Passenger Side L/H on R/H/D vehicle |
simbad111 Member Since: 10 Feb 2014 Location: wolverhampton Posts: 114 ![]() ![]() ![]() |
update changed struts this morning fitting the red on the right and what a difference, so much better than the crap SGS struts, tail gate now lifts itself slowly, |
That's good. |
foxtrotzulu Member Since: 04 Sep 2015 Location: West Berkshire Posts: 152 ![]() ![]() ![]() |
The tailgate on my 2010 facelift RRS is quite heavy to pull down at first and then shuts with enough force that I've never understood why there is a 'powerclose' feature. When opening you also have to use a fair amount of effort. Do I need new gas struts? |
i would say so, use genuine struts, i found that using aftermarket ones make things worse, |
Thanks. I'll change them. |
Please make sure you support the tail gate with a length of timber before removing either strut |
Oh, hadn't thought about that. Thanks. |
