Home > My Range Rover Sport > Alarm fault bonnet switch ?
Paulweeks
2008 Range Rover Sport TDV6 HSE Rimini Red
My alarm goes of now and again and I suspect the bonnet switch ? The bonnet open warning light has flashed up a couple of times whilst driving, can anyone tell me where to find it and whether it is easy to fit a new one ? Thanks in advance for any help .
Post #483245 Wed Dec 23 2015 10:25pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Hi Paul, and a Merry Christmas to You.
The bonnet switch is located in the right
bonnet lock.
It has a little lever on it, that presses against a
microswitch when closed, sometimes You only have
to adjust the lever.
If that doesn't work, You can release the connector
form the switch and take a paperclip and short it,
a temp fix until You can get a new switch.
IFRC the switch isn't that expensive, about £5-12..
Rgds
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #483299 Thu Dec 24 2015 11:33pm
Ian.H
Also have a look at the rubber adjuster "bungs" on the bonnet itself (think they're on the bonnet, if not, poking out of the slam panel). I had an issue that after I closed the bonnet, I had the horn beep when alarming the car and it pointed to the bonnet. I ended up slightly adjusting the rubber stops and this instantly fixed the issue. I guess it was either sitting just a few mm too high or low and was causing a problem.
A cheap possible fix to look into too maybe?
Cheers & Merry xmas...
Ian
Post #483300 Thu Dec 24 2015 11:45pm
D6EML
Scotland 2009 Range Rover Sport TDV8 HSE Stornoway Grey
I'm having the same issue , Iv bought a replacement switch , my question is how do you remove the old one ? Does the washer bottle need to be removed first ?
Dean 2009 TDV8 RRS Stornoway grey
Check out my Autobiography conversion
http://www.rrsport.co.uk/forum/topic41605.html
Post #485609 Sun Jan 24 2016 10:37am
Disco_Mikey
Grill off, release 2 plastic clips, and it slides downwards. Takes 60 seconds to replace Thumbs Up
Post #485613 Sun Jan 24 2016 10:54am
