Home > My Range Rover Sport > Alarm fault bonnet switch ? |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 |
Hi Paul, and a Merry Christmas to You.
Thu Dec 24 2015 11:33pm |
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 |
Also have a look at the rubber adjuster "bungs" on the bonnet itself (think they're on the bonnet, if not, poking out of the slam panel). I had an issue that after I closed the bonnet, I had the horn beep when alarming the car and it pointed to the bonnet. I ended up slightly adjusting the rubber stops and this instantly fixed the issue. I guess it was either sitting just a few mm too high or low and was causing a problem.
Thu Dec 24 2015 11:45pm |
D6EML Member Since: 30 Jul 2015 Location: West lothian Posts: 124 |
I'm having the same issue , Iv bought a replacement switch , my question is how do you remove the old one ? Does the washer bottle need to be removed first ?
Sun Jan 24 2016 10:37am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Grill off, release 2 plastic clips, and it slides downwards. Takes 60 seconds to replace |
Sun Jan 24 2016 10:54am |
