![]() | Home > Maintenance & Modifications > Just fitted a 2012 one piece Tailgate to my sport |
I am NOT knocking the conversion you have done, what you have done to a low spec car is another story altogether, I take my hat off to you |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
Good job we are all different then |
When I upgrade to the New Range Rover Sport I'll end up doing the same |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 ![]() |
Can you do mine please ![]() |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Hey Buddy, just found your next project |
Hi Andy no problem find a tailgate mate and I'll fit it for you. ![]() |
Col that sunroof is too small ![]() ![]() |
Here you go Mate, even avaliable from a forum member. |
Oh deer oh deer |
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 ![]() ![]() ![]() |
Guess there's more than one..... Why the hostility? You put on a single piece tailgate, which is neither powered nor has the correct hinges. I merely asked why you did it, and you launch into yawning and whistling emoji's....... But of a dick move, but fair enough. Your motor to do th what you like. I don't like it, and it's one of the things I miss most about my 2010HSE. MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports |
If you read the posts where does it say it has the incorrect hinges ???? I put the correct hinges on. The 2 piece hinges will not even fit.
I got a WAG who wants things lol...... |
markryan15 Member Since: 30 Oct 2015 Location: Virginia, USA Posts: 22 ![]() ![]() ![]() |
Is there any way you could post a wiring diagram showing the mod you did to get the middle tailgate switch to open? I have a 2008 RRS and like the look of the silver strip. However, I would need the rear switch to work because my vehicle does not have the specific boot release switch on the key fob. (yes i know the bottom LR button on the key can be programed but it can also be easily accidentally un-programmed to do something different, then I would be stuck with a boot that doesn't open. |
