Home > General > Engine oil extraction pump
Ned
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Fuji White
Evening all, can any body recommend a oil pump extractor please thinking of doing my own stealers want silly dosh.
Post #482145 Thu Dec 10 2015 7:57pm
Paddi
Never used one so can't answer your question. Would an even cheaper solution be go buy the correct oil from a discount store such as Eurocarparts and a genuine filter and drain plug from Duckworths and get a decent local garage to do it for you while you keep your nice clean hands round a mug of tea? 2008 MY Java Black TDV8 HSE
Post #482249 Sat Dec 12 2015 1:52pm
Ned
Thanks paddi yer good idea hadn't thought of that, but I do like doing my own I then know it's been done properly
By the way does changing the engine oil and filter affect my 2 year warranty ?..
Post #482258 Sat Dec 12 2015 3:42pm
Paddi
Yes I feel the same way about doing own servicing.
You should check the small print of your warranty but invariably there is a clause specifying the vehicle must be serviced in accordance with manufacturer's recommendations. In the event of a dispute it might be difficult to prove that you have done the service yourself in accordance with that requirement.
Looks like your best bet is find a good independent Land Rover specialist. 2008 MY Java Black TDV8 HSE
Post #482305 Sun Dec 13 2015 10:38am
Tyrefitter
No it doesn't affect your warranty as long as the garage is vat registered & they use LR approved parts & stamp the book.I do a few RRS's & BMW's for folk in my area.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #482306 Sun Dec 13 2015 11:22am
Ned
Cheers enjoy your day👍.
Post #482308 Sun Dec 13 2015 11:25am
fjanssen
Belgium 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Tdv8 must be drained by the plugs..
For other cars I use the Pela Pro 14.. This is an excellent extracter...
Post #482487 Tue Dec 15 2015 8:29am
Tim in Scotland
You can still buy your own oil and filter at less than LR dealers charge and ask the dealer to use those when youy want an oil change. I think you might find that you will have a bit of small print regarding servicing within an extended/ aftermarket warranty but then there would be nothing to stop you say doing opil changes part way through a service.......... who could complain that you change the oil at the halfway mileage between services yourself? Whistle 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #482492 Tue Dec 15 2015 9:13am
jochem00
I don't get you.
you want to make sure it is going to be done the right way! and you started the topic with getting the oil out via an oil extractor.
you won't get al the oil out via an extractor as there are 2 sumps.
Best is to go underneat the car and take the two drains out.
it take me less than 15 minutes to do an oil change. last time I didn't even use a ramp. just put the car in offroad hight
Post #482561 Wed Dec 16 2015 10:21am
Paddi
15 minutes Shocked !
What's your day job - Lewis Hamilton's front left wheelman?
I can make that job last all morning from the 15 mile warm up run to the clean up and disposal of the oil we're talking a good couple of hours Rolling with laughter 2008 MY Java Black TDV8 HSE
Post #482581 Wed Dec 16 2015 2:23pm
Ned
Jochem00
My RRS is the 3.0L sdv6 not a V8 so I think it on as 1 sump plug and not 2 plugs 😄.
Post #482604 Wed Dec 16 2015 5:01pm
