Home > In Car Electronics > Internal Switched 12V
garrycol
Australia
I have to hard wire a Dash Cam into my 07MY TDV6.
Before I grab the multi meter and go searching can someone recommend a spot on the cabin fuse box to take switched 12v power from. I would prefer a vacant spot in the fuse box but failing that as recommended used spot.
Better still, is there switched power up in the overhead console.
Thanks
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #482098 Thu Dec 10 2015 8:31am
Paddi
Follow this link and scroll down to the 6th post for a neat description of how to get switched power from the overhead console:
http://www.rrsport.co.uk/forum/topic10937.html
It worked for me. You'll obviously have to use a hardwire kit to step the voltage down for the camera and these tend to come with much longer cables than you need for such a short run. Reduce the length of the cables as much as you can as they can emit RF and cause interference on the radio owing to the close proximity of the aerial incorporated into the windscreen. Although it only seems to be a problem when the station you are listening too is a bit weak. 2008 MY Java Black TDV8 HSE
Post #482116 Thu Dec 10 2015 12:35pm
garrycol
Australia
Paddi - thanks for that link - all straight forward.
I don't have to worry about any RF as my aerial is not in the windscreen but is in the rear side cargo area glass but thanks for the tip.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #482118 Thu Dec 10 2015 12:49pm
Paddi
Oh gosh - you're right of course. Forgotten that. Makes it all the more surprising that I get a bit of interference . I'm going to try and shorten the lead from the transformer to the camera a bit more. Main reason I think though is that the stations I want to listen to are on the limit of FM reception. Local stations are loud and clear (but are complete CR*P). 2008 MY Java Black TDV8 HSE
Post #482127 Thu Dec 10 2015 3:19pm
garrycol
Australia
Thanks for that. I am going to wire in a small USB socket which has the 12v to 5v reducer built in.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #482159 Thu Dec 10 2015 11:31pm
garrycol
Australia
Pulled the light - didn't quite go to plan as the mounting frame also came out - the fitting needs to be treated gently not the sharp pull as suggested.
See my response here
http://www.rrsport.co.uk/forum/post482167.html#482167
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #482168 Fri Dec 11 2015 8:11am
garrycol
Australia
Different spec cars seem to have different wiring - on my TDV6 the green and white wire is NOT switched and in fact seems to do nothing.
The Blue and Purple wire is constant 12v, the black wire is an earth and I do not have the solid purple wire - in its place I have a brown wire that is 12v when the door is open and is 12v for a few seconds when the ignition is turned off - fades from 12v to 0 volts over 2 seconds.
umbertob wrote:
Detail of the hot connection to the overhead lights harness. Make sure you pick the striped green/white wire only, the others are either not 12v or they are unswitched
So it would seem I do not have ignition energised 12v up in my overhead console.
So back to my original question - where is the best place to take switched 12v from the cabin fuse box or even in the underdash area area above the brake pedals?
Thanks
Garry
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #482290 Sun Dec 13 2015 3:05am
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Maybe piggy back fuse is your only option. Mine is fitted as per these instructions
http://www.rrsport.co.uk/forum/topic28640.html?highlight=blackvue
Post #482304 Sun Dec 13 2015 10:30am
garrycol
Australia
Yes I think so - I will chase up some tomorrow after I have done some work on the fusebox with the multimeter.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #482307 Sun Dec 13 2015 11:23am
Paddi
The green/white wire goes live when the car is unlocked (lights up the overhead console) and after a few minutes goes dead but when car is started it is live again. On stopping the engine it remains live for a few minutes and then goes to off after a few minutes.
At least that is what mine does. So when you are sat in the car with engine off it can be a bit confusing when a meter shows no current. Had me foxed at first until I figured out what was happening. 2008 MY Java Black TDV8 HSE
Post #482328 Sun Dec 13 2015 6:37pm
Bodsy
Site Sponsor
I just use a piggyback fuse on fuse 58 behind the lower glovebox. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #482341 Sun Dec 13 2015 8:36pm
garrycol
Australia
Now that is interesting to know. I will check it out.
However may not suit my needs as it would be nice to have the cam still working with engine off and ignition on. I am thinking of the scenario where there is an incident and you stop to discuss the incident but want the cam to continue running to record the discussion in case the other party gets a bit bolshie. Crying or Very sad
Bodsy - thanks for that. My local electronics shop does not have "piggy back" fuses but does have a similar product which is a standard fuse with a wire coming off the back of the "dead" side to power the accessory.
Thanks to everyone for your input - greatly appreciated.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #482353 Mon Dec 14 2015 12:24am
garrycol
Australia
All done - the green and white wire still had no power at all - but there may have been a reason for that.
I couldn't get a piggy back fuse fitting but was able to buy fuses that had a power wire off them.
So I ran a single wire from fuse 58 (Telephone, infotainment display, multi-media module, TV tuner) up to the overhead light fitting. In the fuse box the lower contact of number 58 is the active side so I put the fuse in so the accessory lead is on the dead side so the fuse covers the original function and power to the dash cam.
Up in the overhead console I installed a USB socket that fits where the sunroof switch would have been if I had a sunroof. I just plugged in the the USB cable and ran it out the spot where the rear vision power cable runs - the dash cam worked fine.
Taking power for fuse 58 means that it stays powered like the radio does. Switch off and remove the ignition key and power stays on for about 2 minutes then switches off. Switch off and leave the ignition key in the ignition and power stays on for about 10 minutes - ignition on accessory and power stays on.
Now that it all works I reassembled the light fitting and the overhead light worked but the map lights wouldn't Sad . Now I normally look for the easy and obvious things first but this time I didn't follow my own advice.
After about an hour of stripping down the entire light fitting it dawned on my I check the fuse - doh blown Confused Maybe that is why the green and white wire did not have power. the map lights are on a different circuit to the interior light.
Now it is No 1 fuse - the top left of the fuse box - designers of these cars should be made to work on them - it is the hardest spot to get at. Now trying the get the new fuse it I dropped it - never to be seen again - the A pillar runs down beside the fuse and it has a big hole so the fuse goes into there almost all the way down to the sill. So out with another fuse and this time use the little tweezer thing but the spot is too hard to get too and the plastic too and another fuse down the big hole.
Here is a pic of where it is take through my borescope still holding the fuse
A further fuse lost down the hole so there are 3 down there Sad . So I tied some string to me spare fuse with wire on it and managed to get it in.
So - everything reassembled and working.
Thanks for the help.
Garry
Oh - I moved my old dash cam to the back window so now looking for switched 12v in the upper tail gate around the wiper, number plate light, upper tailgate latch area. Any ideas?
Cheers 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #482399 Mon Dec 14 2015 11:47am
garrycol
Australia
Fuse 58 is maybe not the best choice as i found today. When you unlock the car even with the ignition off the circuit powers up so the dash cam comes on - not such an issue, however when you start the car power is cut and confuses the dash cam so it shuts down - so I need to switch the car off and restart to reset the dash cam. So another take off is needed.
Fuse 55 which is for the cig lighter just comes on and off with the ignition so is maybe the place to take power from. So I will swap over and see what happens.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #482491 Tue Dec 15 2015 9:01am
garrycol
Australia
Fuse 55 - the lighter fuse is no good either - it has permanent 12v to the fuse box and is switched through the ignition switch and through the socket as the power finds its way to earth. So with the cam plugged in to 55 the cam is on all the time.
Maybe a good spot to take permanent power from.
Fuse 19 (rear console power socket) is the one to go for - it is fully switched with no funny stuff - no power when ignition off and power on accessory and ignition on.
There, of course maybe other spots but I haven't checked them.
The RRS has a mix of switching on the upside (+ive) of the fusebox and on the downside (-ive). Also on others that are various timers and delays and can cause a lot of confusion.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #482553 Wed Dec 16 2015 7:55am
