Home > In Car Electronics > Internal Switched 12V |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
I have to hard wire a Dash Cam into my 07MY TDV6.
Thu Dec 10 2015 8:31am |
Follow this link and scroll down to the 6th post for a neat description of how to get switched power from the overhead console:
Thu Dec 10 2015 12:35pm |
Paddi - thanks for that link - all straight forward.
Thu Dec 10 2015 12:49pm |
Thanks for that. I am going to wire in a small USB socket which has the 12v to 5v reducer built in.
Thu Dec 10 2015 11:31pm |
Pulled the light - didn't quite go to plan as the mounting frame also came out - the fitting needs to be treated gently not the sharp pull as suggested.
Fri Dec 11 2015 8:11am |
Different spec cars seem to have different wiring - on my TDV6 the green and white wire is NOT switched and in fact seems to do nothing.
So it would seem I do not have ignition energised 12v up in my overhead console. So back to my original question - where is the best place to take switched 12v from the cabin fuse box or even in the underdash area area above the brake pedals? Thanks Garry Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Sun Dec 13 2015 3:05am |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 |
Maybe piggy back fuse is your only option. Mine is fitted as per these instructions
Sun Dec 13 2015 10:30am |
Yes I think so - I will chase up some tomorrow after I have done some work on the fusebox with the multimeter.
Sun Dec 13 2015 11:23am |
The green/white wire goes live when the car is unlocked (lights up the overhead console) and after a few minutes goes dead but when car is started it is live again. On stopping the engine it remains live for a few minutes and then goes to off after a few minutes.
Sun Dec 13 2015 6:37pm |
I just use a piggyback fuse on fuse 58 behind the lower glovebox. Bodsys Brake Bible
Sun Dec 13 2015 8:36pm |
Now that is interesting to know. I will check it out. However may not suit my needs as it would be nice to have the cam still working with engine off and ignition on. I am thinking of the scenario where there is an incident and you stop to discuss the incident but want the cam to continue running to record the discussion in case the other party gets a bit bolshie. Bodsy - thanks for that. My local electronics shop does not have "piggy back" fuses but does have a similar product which is a standard fuse with a wire coming off the back of the "dead" side to power the accessory. Thanks to everyone for your input - greatly appreciated. Cheers Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Mon Dec 14 2015 12:24am |
All done - the green and white wire still had no power at all - but there may have been a reason for that.
Mon Dec 14 2015 11:47am |
Fuse 58 is maybe not the best choice as i found today. When you unlock the car even with the ignition off the circuit powers up so the dash cam comes on - not such an issue, however when you start the car power is cut and confuses the dash cam so it shuts down - so I need to switch the car off and restart to reset the dash cam. So another take off is needed.
Tue Dec 15 2015 9:01am |
Fuse 55 - the lighter fuse is no good either - it has permanent 12v to the fuse box and is switched through the ignition switch and through the socket as the power finds its way to earth. So with the cam plugged in to 55 the cam is on all the time.
Wed Dec 16 2015 7:55am |
