Home > Technical > Heated rear window
Panavia man
Heated rear window
I know in the scheme of things this isn't a major problem but have just noticed my heated tread screen isn't working on my 2008 TDV8. Any ideas please? Thanks
Post #480683 Sun Nov 22 2015 6:35pm
Panavia man
Sorry that's rear screen!
Post #480684 Sun Nov 22 2015 6:36pm
Could well be the connector plug in the rear spoiler. It corrodes and you lose the rear screen.
http://www.rrsport.co.uk/forum/topic29082-15.html Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #480686 Sun Nov 22 2015 6:42pm
Panavia man
Cheers- is it easy to get at?
Post #480687 Sun Nov 22 2015 7:01pm
It's not too bad to get at. I found the actual connector was a pig to open up. 2012 SDV6 - it's missing a couple of cylinders
Post #480689 Sun Nov 22 2015 7:09pm
Panavia man
Ok cheers will have a go!
Post #480690 Sun Nov 22 2015 7:26pm
Fighter3d
Italy 2008 Range Rover Sport TDV6 HSE Bonatti Grey
Hi my rear screen heater does not work properly some wires does not work
What can i do ?
Thks
Post #481521 Thu Dec 03 2015 7:04am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
If the wires are visibly broken you can't do anything other than fit a new rear screen which is around £650, your insurance company may pay for it under your glass cover. Thumbs Up
Post #481523 Thu Dec 03 2015 9:49am
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
If you don't want to spring for a new screen, you can get filament repair kit at auto parts store that you paint over the gap with and try that ...cheap fix.
Post #481608 Fri Dec 04 2015 6:35am
Panavia man
Thanks for all the advice - will report back!
Post #481940 Tue Dec 08 2015 3:50pm
