Home > Technical > Heated rear window |
Panavia man Member Since: 27 Oct 2015 Location: North west Posts: 94 |
Sorry that's rear screen! |
Sun Nov 22 2015 5:36pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
Could well be the connector plug in the rear spoiler. It corrodes and you lose the rear screen.
Sun Nov 22 2015 5:42pm |
Cheers- is it easy to get at? |
Sun Nov 22 2015 6:01pm |
It's not too bad to get at. I found the actual connector was a pig to open up. 2012 SDV6 - it's missing a couple of cylinders
Sun Nov 22 2015 6:09pm |
Ok cheers will have a go! |
Sun Nov 22 2015 6:26pm |
Fighter3d Member Since: 28 Feb 2015 Location: Martina franca Posts: 44 |
Hi my rear screen heater does not work properly some wires does not work
Thu Dec 03 2015 6:04am |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
If the wires are visibly broken you can't do anything other than fit a new rear screen which is around £650, your insurance company may pay for it under your glass cover. |
Thu Dec 03 2015 8:49am |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 |
If you don't want to spring for a new screen, you can get filament repair kit at auto parts store that you paint over the gap with and try that ...cheap fix. |
Fri Dec 04 2015 5:35am |
Thanks for all the advice - will report back! |
Tue Dec 08 2015 2:50pm |
