Home > In Car Electronics > 2008 Sport phone connection drops with Iphone 5s |
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 |
I suspect it may the module/phone compatibility. A lot of people (myself included) have had the D4 module fitted which does away with these issues, and the newer module has a far greater compatibility with modern phones. Once your posting count has gone up a bit, PM Bodsy (Ian) on here. He retrofits on RR/Discos and he will be able to sort you out. He may even see this thread. Knows his stuff. |
Sat Nov 14 2015 9:48pm |
If you get the Phonebook, then the software on the module is the latest one.
Sun Nov 15 2015 1:43pm |
DJP Member Since: 14 Nov 2015 Location: south Posts: 3 |
Thanks. I really appreciate the help. I have disconnected the cables from the battery and touched together for 20 secs, reconnected, but this has not solved the problem.
Sun Nov 15 2015 2:49pm |
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 |
What iOS version are you running DJP?
Sun Nov 29 2015 1:21pm |
9.1 |
Sun Nov 29 2015 1:29pm |
