Home > In Car Electronics > Range Rover Stormer 09 - No Aux Socket?
mcniven
United Kingdom 2009 Range Rover Sport TDV6 HST Sumatra Black
Evening guys looking for some advice already searched the net and cant find the answer. Just bought this car, but it has no aux input socket anywhere, it has the button on the radio but no socket anywher, not behind centre console not on dash etc.
Post #479223 Mon Nov 09 2015 5:42pm
mcniven
Post #479224 Mon Nov 09 2015 5:46pm
Should be under the flap by the rear power socket between seats next to rear air vents.
Post #479225 Mon Nov 09 2015 5:53pm
mcniven
Col thats whhat i have there nothing there
Post #479226 Mon Nov 09 2015 5:54pm
Hi
That's really odd that's certainly where mine was on my old 09 plate.
Post #479227 Mon Nov 09 2015 5:57pm
mcniven
Even if any1 can offer any advice on what I could buy to give me the aux function! Thanks for any input
Post #479228 Mon Nov 09 2015 6:02pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
The Stormer is based on the basic S model so has no Aux as standard, there will be a feed on the back of the radio unit that a competent auto electrician could access and create an Aux for you.
I had it done on mine and it works brilliantly, I then fitted one of these to http://www.amazon.co.uk/Bluetooth-Receiver...ds=esynic3
Post #479313 Tue Nov 10 2015 9:46am
rangeroverman
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
I have the whole cubby box and vents with the aux and rca inputs for sale.
You will have to take out your existing one and replace with the part I mentioned .
I'm not 100% certain but I'm pretty sure the wiring/connectors will be in place already once you remove the original setup you have there .
Let me know if of interest to you RRsport 2.7 tdv6 HSE
Post #479348 Tue Nov 10 2015 2:36pm
