Home > Technical > Steering wheel / Tracking problems |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
Did the garage that did the alignment give you a print out of the suspension settings? If not, why not would be my first question. The steering wheel can be set to be level when the wheels are aligned; if it is a long way out then it might need to be removed and rotated on the splines. If it's a long way out of level then that begs the question as to whether there is something amiss on the track rods - perhaps they have been adjusted to their limits.
Sun Oct 25 2015 9:37am |
RR Richie Member Since: 13 Oct 2015 Location: Newark on Trent Posts: 9 |
Thanks
Sun Oct 25 2015 9:40am |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677 |
Take it to a garage that has the Hunter alignment system & make sure they know what they are doing,,I've got a computerised system in my tyre bay but only do the tracking with it as the ramp/lift we use is usually being used for mot's.
Sun Oct 25 2015 11:49am |
Taking it in on Friday to a different place. Drove another virtually the same with 22's, his was stright as a dice so something is wrong with mine.
Mon Oct 26 2015 11:51pm |
