Home > Technical > Fuel rail pressure sensor
Lauren_j23
2007 Range Rover Sport TDV8 HSE Stornoway Grey
My range wouldn't start, was diagnosed as fuel rail pressure sensor. Can anybody tell me where on the engine I would find this, so I can locate the part number ?
Post #476488 Thu Oct 15 2015 5:02pm
Stand at front of car, Left Hand bank of cylinder's fitted to end of fuel rail nearest bulkhead if I remember right.
Post #476493 Thu Oct 15 2015 6:02pm
Lauren_j23
Do you know to remove it would it require removing the scuttle panel ? Many thanks
Post #476494 Thu Oct 15 2015 6:09pm
Have a feeling you cannot buy Sensor separately its part of the Fuel Fail LR020019 £200.00 from L/R .
I don't think you have to remove Scuttle Panel but really can't remember, but the panel is easy enough to remove anyway.
I think you need to wait for Disco-Mikey to come along, I'm sure he will put you right.
Post #476498 Thu Oct 15 2015 6:22pm
Lauren_j23
I need to get the part off firstly as need to confirm the part numbers with Land Rover
Post #476499 Thu Oct 15 2015 6:31pm
LR020019 is the part number of the complete rail and there appears to be only one listed for the TDV8. E-mail Dan at Duckworth's I'm sure he will help you and tell you if the sensor is available separately.
Post #476500 Thu Oct 15 2015 6:47pm
