Home > Technical > Fuel rail pressure sensor |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Stand at front of car, Left Hand bank of cylinder's fitted to end of fuel rail nearest bulkhead if I remember right.
Thu Oct 15 2015 6:02pm |
Lauren_j23 Member Since: 27 Jul 2014 Location: Wales Posts: 8 |
Do you know to remove it would it require removing the scuttle panel ? Many thanks |
Thu Oct 15 2015 6:09pm |
Have a feeling you cannot buy Sensor separately its part of the Fuel Fail LR020019 £200.00 from L/R .
Thu Oct 15 2015 6:22pm |
I need to get the part off firstly as need to confirm the part numbers with Land Rover |
Thu Oct 15 2015 6:31pm |
LR020019 is the part number of the complete rail and there appears to be only one listed for the TDV8. E-mail Dan at Duckworth's I'm sure he will help you and tell you if the sensor is available separately.
Thu Oct 15 2015 6:47pm |
