Home > General (L494) > Error message on new sport |
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 |
Ring land rover assist or your supplying dealer , probably nothing to worry about . |
Fri Sep 11 2015 9:06pm |
Josh Bear Member Since: 19 Oct 2011 Location: UK Posts: 60 |
Thanks both.
Fri Sep 11 2015 9:24pm |
No. Only just happened as I came in a few mins ago. I knew there was a fix for the tank slapping sound just not had it done.
Fri Sep 11 2015 9:30pm |
Thanks for the help. Will call them tomorrow |
Fri Sep 11 2015 9:38pm |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
Nothing to worry about. I've had this twice on my 15 plate RRS but not before on my 13 plate same model. The DPF seems a lot more sensitive now on RRS's doing low miles. Have a look at the handbook - I think the filter needs to regenerate every 300-500 miles, and if the engine has not got up to full working temp when the cycle is due , the warning light comes on. It happened to me last week, so all I did was to drive for 10 mins to the local supermarket, shove a few bottles in the bottle bank, with the engine running, then kept it running whilst I put some diesel in the the pay per pump (ok probably should have switched it off) and then legged it home in Sport mode. The warning light came off 1 mile from home.
Fri Sep 11 2015 9:45pm |
Hi
Sat Sep 12 2015 2:21pm |
It is a problem for all modern diesels fitted with a DPF, not just Land Rovers. If you drive a lot in stop start, slow moving traffic and the engine isn't getting warmed through properly then the regeneration doesn't take place like it should. I appreciate that it shouldn't in this day and age, but that is progress for you! In 6 months and 3200 miles driving I haven't suffered from this issue or on any of the lprevious 2 cars fitted with DPF's but then my driving is mostly fast A roads at cruising speeds and not commuter type driving. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Sep 12 2015 2:36pm |
Thanks. My driving is dominated by my commute of 15 miles on country roads. Generally the roads are quiet so reasonable speeds are possible. I did this commute with my previous RRS and never had an issue. The travel pattern hasn't changed but now I have this message.
Sat Sep 12 2015 2:44pm |
Did your last RRS have a DPF? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Sep 12 2015 3:46pm |
No idea
Sat Sep 12 2015 5:21pm |
This link to the AA ref DPF may be of interest. As Tim says, this is a common issue for many modern diesels fitted with DPF filters.
Sat Sep 12 2015 7:27pm |
