![]() | Home > General (L494) > Error message on new sport |
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 ![]() ![]() |
Ring land rover assist or your supplying dealer , probably nothing to worry about . |
Josh Bear Member Since: 19 Oct 2011 Location: UK Posts: 60 ![]() |
Thanks both.
No. Only just happened as I came in a few mins ago. I knew there was a fix for the tank slapping sound just not had it done.
Thanks for the help. Will call them tomorrow |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
Nothing to worry about. I've had this twice on my 15 plate RRS but not before on my 13 plate same model. The DPF seems a lot more sensitive now on RRS's doing low miles. Have a look at the handbook - I think the filter needs to regenerate every 300-500 miles, and if the engine has not got up to full working temp when the cycle is due , the warning light comes on. It happened to me last week, so all I did was to drive for 10 mins to the local supermarket, shove a few bottles in the bottle bank, with the engine running, then kept it running whilst I put some diesel in the the pay per pump (ok probably should have switched it off) and then legged it home in Sport mode. The warning light came off 1 mile from home.
Hi
It is a problem for all modern diesels fitted with a DPF, not just Land Rovers. If you drive a lot in stop start, slow moving traffic and the engine isn't getting warmed through properly then the regeneration doesn't take place like it should. I appreciate that it shouldn't in this day and age, but that is progress for you! In 6 months and 3200 miles driving I haven't suffered from this issue or on any of the lprevious 2 cars fitted with DPF's but then my driving is mostly fast A roads at cruising speeds and not commuter type driving. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thanks. My driving is dominated by my commute of 15 miles on country roads. Generally the roads are quiet so reasonable speeds are possible. I did this commute with my previous RRS and never had an issue. The travel pattern hasn't changed but now I have this message.
Did your last RRS have a DPF? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
No idea |
This link to the AA ref DPF may be of interest. As Tim says, this is a common issue for many modern diesels fitted with DPF filters.
