Home > Australia & New Zealand > Prodigy 3 brake controller install help
savi18
New Zealand
Auto electrician fitted dedicated towing wiring harness to RRS 2009 also have the external module for LED light on trailer, the next thing to install is my prodigy 3 brake controller, if my RRS has the factory plug under dash drivers side thats easy to fit the brake controller but what about the wiring to the rear towbar harness how does the brake controller work from here is there extra wiring to be fitted through the 7 pin socket, Cheers
Post #470726 Wed Aug 19 2015 10:06am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
I thought the Brake controller cable was usually separate from the 7 pin, but
usually wrong Laughing Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #470727 Wed Aug 19 2015 10:20am
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
I have 7 pin with Electric brakes on my van. You would need to find out which 'pin' on the van 7 pin is for the electric brakes.
Then the output wire needs to be run from the Prodigy unit to the 7 pin socket on the RRS to match the van. (there may already a wire running to the white UK plug if you have one)
I had mine unit installed by Auto elec. as I was not to sure of picking up the correct wiring for unit.
The mounting was another issue due to lack of suitable places in an RRS and he suggested in the drivers footwell next to the centre console
They have to be level and although low its fine and not in the way.
Post #471802 Wed Sep 02 2015 10:34pm
