![]() | Home > Australia & New Zealand > Prodigy 3 brake controller install help |
savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 152 ![]() ![]() |
Auto electrician fitted dedicated towing wiring harness to RRS 2009 also have the external module for LED light on trailer, the next thing to install is my prodigy 3 brake controller, if my RRS has the factory plug under dash drivers side thats easy to fit the brake controller but what about the wiring to the rear towbar harness how does the brake controller work from here is there extra wiring to be fitted through the 7 pin socket, Cheers |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
I thought the Brake controller cable was usually separate from the 7 pin, but
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
I have 7 pin with Electric brakes on my van. You would need to find out which 'pin' on the van 7 pin is for the electric brakes.
