Home > General (L494) > Deployable side steps - how to keep deployed? |
Nowaytk Member Since: 27 May 2013 Location: London Posts: 183 |
If you just have the ignition on ( engine not running and doors closed ) press and hold the button under the tailgate release within 3 seconds of turning the ignition on, they will then deploy until either you drive above 5 kph or lock the car. You can turn the ignition off and they will stay deployed . repeat the above process to stow.
Mon Aug 03 2015 7:03am |
Skittles001 Member Since: 09 Jun 2015 Location: Surrey Posts: 9 |
thanks! Will give it a whirl tonight. |
Mon Aug 03 2015 7:35am |
RobF Member Since: 11 Oct 2013 Location: Suffolk Posts: 56 |
But don't rush to do it after shutting down. It seems to take around a minute before the steps will deploy on pressing the button. |
Mon Aug 03 2015 1:20pm |
When I take mine to get washed, I pull up, turn off, then put ignition on and they come out, no need to wait, maybe I'm just lucky? 2015 HSE SDV6 Scotia Grey, ebony / lunar, colour coded, deployable steps, TV, sliding pano and a few other bits. Now gone
Mon Aug 03 2015 1:49pm |
