Home > Faults & Fixes > Revs Dropping and Vibration
sawanr
Kenya 2008 Range Rover Sport TDV6 HSE Santorini Black
Hi,
I have a 2008 RRS, I have been having some trouble with it and no one can help me sort it out.
While the car is driving well, at particular times, above 2000 rpm, the revs start dropping and a vibration occurs underneath, the vibration is like when you are driving over rumble strips.
I have given the car to many garages, one flushed the engine, other replaced the bearing on the rear diff, and another said there is something wrong with the Active Cornering System.
Is anyone facing the same problem and has found a solution!!
Thanks
Sawan
Post #467197 Sat Jul 11 2015 8:28am
gogsy1956
Sounds a bit like the torque converter,,,,,, sometimes referred to as the cattle grid effect. Do a search on here for that subject or vibration issues 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #467203 Sat Jul 11 2015 10:09am
sawanr
Thank you very much gogsy1956
Post #467373 Mon Jul 13 2015 7:07am
