Home > General > TDV8 Turbo failure
Loco98
Ireland 2012 Range Rover Sport 3.0 TDV6 HST Santorini Black
It seemed that way to me from the forum... This forum is reason i bought 3 year warranty when purchasing mine. Cheers RRSTDV8
Post #466532 Sat Jul 04 2015 4:26pm
Erniedog
EGR Valve Fault. Does this mean the Turbo needs repalcing
Hi All. After some advice. I have a 2010 V8 90,000 miles with a EGR system fault coming up on the computer even straight after it is cleared..The vehicle goes into restricted performance mode as soon as it is turned on. There is i assume engine oil that has dripped over the floor and has oil in the intake system inter cooler & pipes. Will the faulty EGR valve cause this oil to ingress into the pipes or is there other problems possibly underlying. I have someone looking at it soon, but just want to prepare for any bad news that they may give.....Thanks in advance for any advice
Post #468125 Mon Jul 20 2015 8:21pm
Disco_Mikey
There is no oil in the EGR system...
Post #468129 Mon Jul 20 2015 9:17pm
Erniedog
You can tell I have no mechanical knowledge whatsoever. What can be a possible cause for the oil
In the inter cooler etc. any idea please
Post #468133 Mon Jul 20 2015 10:02pm
Disco_Mikey
Most probable cause will be a turbo issue. Is there lots of oil, or is it just a misting of oil?
Post #468145 Tue Jul 21 2015 6:05am
Erniedog
Quite a bit. Definitely not a misting
Post #468156 Tue Jul 21 2015 7:44am
