Home > Maintenance & Modifications > Servicing air compressor
Morgi27
Hi guys
Going to service the air compressor on 55 plate rrs with new seals and the pellets that go inside and also replace
The lid for a steel one has the plastic one has issues with a split between the pipe inlets
I'm reading that need to disconnect the battery before removing compressor.
Is this really needed? Is it going to cause any problems with anything if i don't?
Cheers guys Smile
Post #463288 Sat May 30 2015 3:49pm
RonyTed
England 2011 Range Rover Sport Supercharged Autobiography Santorini Black
Hi Morgi, removed and replaced my compressor with a new one this week did not disconnect the battery and no probs at all, but would suggest you let the car go to sleep first. I think people are saying disconnect battery to clear faults? dont know if this works as i used IID to clear all faults.
Post #463306 Sat May 30 2015 10:59pm
daxmatt
keep us posted how it goes,,need to do mine soon Very Happy
Post #463312 Sun May 31 2015 7:50am
gogsy1956
Hi Morgi, had mine off once to replace the alloy mount ( trolley jack in wrong place ! ), did not disconnect the battery, couple of warnings when i first switched on but soon cleared.
post some pics when you have the unit stripped down as i have been thinking to do this also,,,, where you getting the bits from,??? i know there is a shop on ebay that carry a range of parts for this . 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #463362 Sun May 31 2015 3:28pm
Morgi27
Cheers guys has I say the compressor is fine and no warnings Etc, just I want to replace the lid from the plastic one to the metal one so I don't get that split inbetween the pipe outlets
Got the kit Come today from ebay was £55 I think seems very good new steel lid
The moisture absorbing beads and the fabric filters to keep beads in place and tools for fixing piston in place to remove also contains seals an new piston seals
Will let you know how it goes once I get time to replace it all,there's also a video on youtube showing how to replace the various parts etc
Post #463676 Wed Jun 03 2015 1:47pm
