Home > General > Auxiliary radiator lifespan |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
On the S/C the auxiliary radiator is actually a supplementary engine oil cooler radiator connected to the oil cooler in parallel to the main coolant flow through the oil cooler. On the TDV8 the auxiliary radiator is just an extension of the engine coolant system. Sorry if you knew that already but it might be useful to know.
Sun May 24 2015 5:22pm |
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 |
Hi they are write at the front and suffer from damage due to stones etc , I have had to fit one on mine , and know of a few other people fitting them for same reason . I fit a grill to protect mine , mine is a hst with large gaps in the bumper , not sure on std bumper , hope that helps john 2007 SUPERCHARGED HST |
Sun May 24 2015 8:09pm |
