Home > General > Auxiliary radiator lifespan
Dream ride
Taiwan
Hello all, how long would an auxiliary radiator last on an 05 supercharged? I'd like to do some preventive maintenance by don't want to start throwing money at it. I've changed all the fluids, plugs and wires. It's got 150k miles on it. I am not the original owner by the way. Thank you all in advance.
Post #462792 Sun May 24 2015 3:35pm
On the S/C the auxiliary radiator is actually a supplementary engine oil cooler radiator connected to the oil cooler in parallel to the main coolant flow through the oil cooler. On the TDV8 the auxiliary radiator is just an extension of the engine coolant system. Sorry if you knew that already but it might be useful to know.
I would expect both to have the same life span as any other radiator with the correct engine coolant/antifreeze mix used. 2012 SDV6 - it's missing a couple of cylinders
Post #462801 Sun May 24 2015 5:22pm
johnunleashed
2007 Range Rover Sport Supercharged HST Java Black
Hi they are write at the front and suffer from damage due to stones etc , I have had to fit one on mine , and know of a few other people fitting them for same reason . I fit a grill to protect mine , mine is a hst with large gaps in the bumper , not sure on std bumper , hope that helps john 2007 SUPERCHARGED HST
Post #462824 Sun May 24 2015 8:09pm
