Home > Australia & New Zealand > Trailer Electrics - Australian Vehicles
garrycol
Australia
My 07MY 2.7 did not come with trailer electrics and I bought the OEM loom etc and plugged it into the car systems. Used the black socket and it provides trailer lights etc as per Aust wiring layout. I removed the fuse to one taillight circuit to stop trailer electric brakes operating when the tail lights are on.
I only wired in the one socket and the other still sits in the spare parts bin. If I were to wire in the second socket what services does it provide?? Is it worthwhile connecting up?
This is for Aussie cars only.
Thanks
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #461673 Sun May 10 2015 1:22am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
only ever used the Black socket on my Trailer electrics.. that said i had to get a
LED module installed so the vehicle recognised when LED based systems were
being plugged in, otherwise the RPS went haywire and the trailer stability would
not work.. important when towing just over a ton of Camper trailer on corrugated roads Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #461898 Thu May 14 2015 6:50am
garrycol
Australia
It has always amazed me that a car maker can sell a car with wiring systems, in this case the trailer wiring system that is not compatible with the specified system in the country of sale - and also that it is not compatible with modern trailer lights systems.
I would have thought that both would have been covered by Australian Design Rules and the vehicle would have to comply but obviously not.
As mentioned my trailer wiring is modified so that the trailer brakes do not come on when I put the headlights on and while my two trailers still have incandescent lights I build a pulse buster so that I can tow trailers with led lights.
I am still not sure what electrical services the white plug provides though. I think one of the pins does provide a steady 12v but not sure what its amperage is or what the other pins provide.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #461906 Thu May 14 2015 9:02am
Zilch
Opposite Lock who fitted the LED module told me they provided the mod on mostly European
marques, Audi, Merc, BMW etc, as well as LR's. Although one may have a permanent 12V feed
Neither of the sockets are rated for charging Trailer batteries (say for a Camper Trailer system)
so got OL to also add a Battery isolator and run a fully rated cable with anderson connector and
co-located these with the rear tow electrics.. So when towing i can recharge on the go
Jim Another Pommie Bar Steward down under
Post #462088 Sun May 17 2015 8:57am
garrycol
Australia
I also have a Anderson plug setup and it works fine - your point about a low power 12v source in the white plug is valid bit because it is low power it is really not much use for anything then begs the question what use is the white socket.
garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #462100 Sun May 17 2015 11:11am
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
"what use is the white socket?"
Not much! Laughing
Regards
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #462133 Sun May 17 2015 8:36pm
garrycol
Australia
So other than one pin providing a constant 12v supply what do the other pins do?? 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #462147 Mon May 18 2015 12:05am
Barryp
Hi Gary,
This is from another European vehicle but connections should be the same. Picture in my gallery.
Regards
Barry
Post #462148 Mon May 18 2015 2:03am
Zilch
Perhaps its designed for fitting large Flux capacitors on US models Whistle Laughing Another Pommie Bar Steward down under
Post #462165 Mon May 18 2015 8:38am
garrycol
Australia
Barry - thanks for that pic. I really cannot see how standard RRS wiring can support the power needs to charge a battery in a camper - especially over the 5 to 6 m from the engine bay to battery in the trailer.
From that, I guess there is no need to plug in my white plug and I might just stay with my anderson plug and heavy wiring.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #462180 Mon May 18 2015 11:18am
Barryp
Gary,
As above:
Not much! Laughing
Another example of a useless EU standard.
Regards
Post #462184 Mon May 18 2015 11:37am
garrycol
Australia
I thinking more I think I will plug in the the wiring to the car but cut off the white plug and run the wiring to two new 12v sockets (pins 4 and 6) in the cargo area as the current single switched 12v socket is a pain when the ignition is turned off.
Also in the above socket diagram, what is the the number 5 socket - sensing device??
Thanks
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #462306 Tue May 19 2015 8:02am
Barryp
Gary,
Only thing that I could find on the 12S socket was this which shows pin 5 as a spare! Shocked
Regards
Post #462532 Wed May 20 2015 9:20pm
garrycol
Australia
Thanks for that - I see that the fridge wire is switched like to one in the rear - not much use for a fridge on a hot day when parked for a while. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #462536 Thu May 21 2015 12:59am
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
I have a 06 Sport which had both white and black plugs fitted.
Just to add/clarify to the posts and diagrams.
The black 7 pin socket is set up for Aust.
1. Yellow - LH blinkers
2. Black - Reversing . Not Fog lights ?? But also used for Aux. Power if no reversing lights. See below
3. White - Earth
4. Green - RH blinkers
5. Aux. Electric Brakes
6. Red - Stop lights
7. Brown- Parkers.
This is different to the diagrams showing seperate wires for the left and right parkers.
I was told that the white socket was for U.K. vehicles. Which is partly correct if you have the Fog lights and seperate the parkers you are going to need more than a 7 pin plug.
I have a van and although the Anderson plug with heavy wiring running from the battery (with cut off switches) may be required for Big fridges. I have found that by running the Pwr wire from the white socket via the fuse holder under the boot floor (easily accessible)into the back of No.2 in the Black socket provides adequate Pwr to run the fridge in the van whilst on the move. It did between Melb. and Bundaberg 3 days of 25 degs +.
Proviso is that the Fridge is cold before you start. Thumbs Up
Post #463655 Wed Jun 03 2015 9:57am
