Home > Technical > Brembo Brakes |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 |
Fellas, can Brembo calipers be fitted straight onto standard HSE discs, is it worth the hassle/expense, and would grooved and/or drilled discs improve braking performance? |
Tue Oct 10 2006 1:09am |
jjb218 Member Since: 22 Jul 2006 Location: Dominican Republic Posts: 94 |
If thats not enough, add the drilled or slotted discs.
Tue Oct 10 2006 5:58am |
Thanks! Can you recommend good pads? What about greenstuff (Red?), are they better than the standard Ferodo? Nobody seems to have slotted discs, any suggestions? Looks like Brembo would cost a fortune so I'll try the other options first.., if I can locate the parts!!! |
Thu Oct 12 2006 3:26am |
In the absence of specific brand recommendation, I'm going to fit Rossini grooved/drilled discs from Car Parts Direct on the front and Kevlar-based pads all round supplied by Twisted Performance. I'll post an update on difference once fitted! |
Sun Oct 22 2006 8:42pm |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 |
Details & pics would be nice = look forward to the results
Mon Oct 23 2006 9:04am |
txu Guy Member Since: 12 Sep 2006 Location: Texas Posts: 3 |
Let us know the performance and amount of dust that you get with the kevlar pads. |
Thu Oct 26 2006 5:41pm |
Will do! Just awaiting front Rossini discs (£210), already have the full set of EBC greenstuff pads (£150), and will update when fitted. Incidentally, the application for the standard TDV6 is identical to D3. |
Sat Oct 28 2006 12:35pm |
Right! Rossini front discs now fitted along with EBC greenstuff pads all 'round. Response is instantly much sharper than standard brakes, even BEFORE the bedding-in process is completed. Undoubtedly better braking, no need to stamp hard on the pedal anymore before bringing the bus to a halt.
Thu Nov 16 2006 1:41am |
Pix = Yes Please
Thu Nov 16 2006 9:20am |
Interesting tip, thanks Phil. Rossini are supposed to be manufactured from superior materials, including strength-improving manganese, but I'll advise if problems develop. Anybody needing further information should contact Martin at Car Parts Direct on 01332 290833 (UK Sole Importers).
Thu Nov 16 2006 1:40pm |
