Home > In Car Electronics > ENGINE FAULT !?!
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
ENGINE FAULT !?!
I have a 2006 Sport. Over the last three days I have driven back from Spain towing a light weight caravan covering 1000 miles. approx. The message ENGINE FAULT came up a few time on the dash and the engine power was considerably reduced ....What could be the problem? Andrew Kennedy
Post #461291 Wed May 06 2015 11:49am
Lost for Words
Could be various things including EGRs, turbo, turbo actuator, turbo hose, fuel pump/filter...
We need fault codes to get any further. Thumbs Up
Was there black smoke? Any other symptoms? Visiting from DISCO3.CO.UK
Post #461301 Wed May 06 2015 1:52pm
andrew kennedy
ENGINE FAULT !?!
Thanks for yours!! Would the problem be shown up using a diagnostic tool? Or is it the case of looking for the answer to the problem by elimination? Grateful for your comments!! Andrew Kennedy
Post #461502 Fri May 08 2015 8:14am
Lost for Words
Sorry I wasn't able to reply sooner. Yes, fault codes and live data from a diagnostic tool will be able to reveal the issue in many cases, or at least give a pointer in the right direction. Thumbs Up Visiting from DISCO3.CO.UK
Post #461709 Sun May 10 2015 7:38pm
pollawyn
United Kingdom 2006 Range Rover Sport Supercharged Cairns Blue
Can an intermittent fault be recovered by the diagnostic tool. I ask because I have experienced the occasional fault message accompanied by loss of power, switching off and restarting has resulted in normal service being resumed. Razz past personal chariots
TVR S1, TVR Chimaera, Mercedes 500SL, all sadly missed but age demanded easier access.
Post #489667 Tue Mar 01 2016 10:14pm
Lost for Words
Yes, fault codes have various different states, so historic faults can still be seen. Thumbs Up Visiting from DISCO3.CO.UK
Post #489697 Wed Mar 02 2016 9:14am
andrew kennedy
I have had exactly the same experience. Due I am told because I have not been using the engine to anywhere near is full potential - basically the exhaust fumes have gunged up a few sensors. You need to consult a garage who knows the workings of Land Rovers who would sort the problem out. Andrew Kennedy
Post #489698 Wed Mar 02 2016 9:19am
pollawyn
engine fault ? EGR
I have a 2006 4.2 supercharged. Engine fault light, I have been told likely to be EGR, have also been told no ESG on petrol engines. Definitive answer please and if EGR present where can I get same. Otherwise magnificent chariot, I smile every time I get in and smile even broader when that engine fires up, who needs a radio. Rolling with laughter past personal chariots
Post #504452 Sat Sep 03 2016 12:17pm
