Home > General > Car lowering itself after parked
D12TYJ
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
Hi all,
Recently realised after i park the car, the car lowers itself when i pull out the key,
But only the rear of the car lowers itself, and not the front.
Is this normal? Or is the whole car suppose to lower itself and just not the rear,
Assuming the front should lower aswell as the rear.
Thanks for any info Thumbs Up
Post #459505 Fri Apr 17 2015 1:53pm
mlines
Is your driveway level? 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #459518 Fri Apr 17 2015 3:04pm
D12TYJ
Yep, flat & level as anything.
Post #459519 Fri Apr 17 2015 3:05pm
mlines
Well mine levels itself off as you describe but is just as likely to be the front depending on the situation 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #459521 Fri Apr 17 2015 3:15pm
zaphod
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
Mine does it too - it's usually the OSF that drops down with a bit a whooshing sound. Freaked me out at first but now I know it's just compensating for being 16 stone lighter on that corner when I get out Laughing
Post #459524 Fri Apr 17 2015 3:38pm
D12TYJ
Hmmm...
My driveways level and even, but always its just the back that lowers itself.
Maybe something's not right on mines then...
Post #459536 Fri Apr 17 2015 4:05pm
Chin
United Kingdom 2010 Range Rover Sport 3.0 TDV6 SE Stornoway Grey
I'm not an expert my any stretch of the imagination but if it were me I'd be suspecting an air leak from my rear suspension
Post #459558 Fri Apr 17 2015 6:52pm
D12TYJ
How could i check this?
Post #459562 Fri Apr 17 2015 7:25pm
Chin
Remembering from past topics on here you should have a play with putting the suspension into 'off road' height and seeing if you get any errors such as 'car rising slowly' or something similar.
Alternatively if not a leak my other guess would be ride height sensors but I'm sure someone who knows a bit more about this stuff will be along soon to give you a more technical answer.
In the meantime id have a play around with the search facility and see if you see anyone else with other similar symptoms.
Post #459569 Fri Apr 17 2015 7:37pm
ziglo
Yep I would say it's a sensor that's gone wrong, book it in with a good mechanic who has the proper software to run it and diagnose the fault.
Post #459594 Fri Apr 17 2015 9:56pm
zaphod
I'm pretty sure I've read that if you park up and disconnect the battery (or pull the appropriate fuses) and the car still lowers then you have a leak... However if it no longer drops then you have a sensor/electronic problem that causes the car to erroneously adjust the height to keep the car 'level'.
Post #459595 Fri Apr 17 2015 10:13pm
Lost for Words
Pull Fuse 26, IIRC. Thumbs Up Visiting from DISCO3.CO.UK
Post #459606 Sat Apr 18 2015 6:51am
martyn05
United Kingdom 2006 Range Rover Sport Supercharged Bonatti Grey
Reverse onto your drive and see if the rear still lowers? 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #459611 Sat Apr 18 2015 7:15am
