Home > In Car Electronics > Retrofit bluetooth |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
You need to fit the BT module from a D4, it more or less a plug and play kit, you would then need it enabling. Contact Disco_Mikey I am sure he can sort you out.
Tue Apr 14 2015 7:31pm |
Roy1980 Member Since: 14 Apr 2015 Location: Glasgow Posts: 3 |
That's great, thank you |
Tue Apr 14 2015 7:44pm |
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 |
Did you have any luck with getting this done mate. I'm in the same boat and if this kit does the job, then happy days. I sent Disco-Mikey a PM but he hasn't read it yet. |
Sun Sep 13 2015 11:43pm |
I wouldn't use that kit tbh, input will work, but you are better off having the d4 module retrofitted. Bodsys Brake Bible
Mon Sep 14 2015 8:04am |
So Bodsy, how much am I looking at for you to do that to my car? I was also looking at the mObridge system. That is good but quite pricey. |
Mon Sep 14 2015 9:39am |
The Mobridge kit is really quite pricey, you're right.
Mon Sep 14 2015 9:41am |
Mon Sep 14 2015 9:47am |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 |
Bodsy - would you be so kind to include me in your PM regarding BT info? I'm in exactly the same boat as Gary (buttons on the steering wheel, no BT module, no harness visible in the rear right boot area, no I don't want to fork out 300 quid for a M0bridge BT, yes, I've seen Ford Focus BT modules that cost a fraction of LR items and look suspiciously similar). Regards etc.,
Mon Sep 14 2015 9:52am |
Bodsys Brake Bible
Mon Sep 14 2015 9:58am |
