Home > Faults & Fixes > Knock
l200jmc
Knock
Hey there guy's i know there is alot of post's on knocking and wha tnot but need abit of help pin pointing or solving my problem. Seem to be if i go over speed bump's at a angle and the cab rock's side to side i got a knocking seem's the be from the rear although i could be wrong. If i hit them straight on no knock, also if i steer left & right sharpish and get the cab rocking i get the knock... I know there's a slight ace bar leak to the rear but its doing my head in now & its 2008 tdv8 no warranty...
Thanks Jamie
Post #458005 Thu Apr 02 2015 9:35am
lugzyboy82
England 2007 Range Rover Sport TDV6 HSE Java Black
I have the same fault mate. Did you find a fix?
Post #460856 Thu Apr 30 2015 2:25pm
Camelrock
Probably ARB 'D' bushes or links. Rock the car does it knock then ? If so you need it over a pit or on a 4 poster ramp to identify which bushes or links. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #461271 Tue May 05 2015 9:56pm
frostmotorsport
New Zealand 2006 Range Rover Sport Supercharged Rimini Red
There are a couple on here (myself included) for whom the knock from the rear is the chassis dampeners swinging and hitting the (modified/aftermarket) exhaust. Worth a look and cheap to test/fix.
Cheers. Every home should have one!
'06 RRS SC Rimini Red
'04 Audi S4 Avant
Escort Mk II Sport
Post #462195 Mon May 18 2015 12:06pm
