Home > Faults & Fixes > Knock |
lugzyboy82 Member Since: 30 Apr 2015 Location: Cheshire Posts: 26 |
I have the same fault mate. Did you find a fix? |
Thu Apr 30 2015 2:25pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Probably ARB 'D' bushes or links. Rock the car does it knock then ? If so you need it over a pit or on a 4 poster ramp to identify which bushes or links. 2008 G4 RRSport TDV8 current
Tue May 05 2015 9:56pm |
frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79 |
There are a couple on here (myself included) for whom the knock from the rear is the chassis dampeners swinging and hitting the (modified/aftermarket) exhaust. Worth a look and cheap to test/fix.
Mon May 18 2015 12:06pm |
