Home > General > Advice on small stone chips?
nickp
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
What do you suggest to deal with small stone chips . I have picked up a couple over the weekend which I have noticed, only small ones but I have noticed them anyway. Should I just leave them as I guess I will pick up more or shold I do something about them .
Also do you think having mudflaps will cut down on the number of small stone chips down the side of the RRS ?
p.s Thanks for all your help on the Alloy Wheel scrape.
Post #2454 Mon Sep 19 2005 11:34am
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
I would recommend getting the mudflaps, I am buying these the day I get mine and will fit them myself, saving about £65. They will make a marked difference to the amount of chips and dirt spraying up the side of the car.
For less than £95 I think they are well worth it, and look good too. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #2456 Mon Sep 19 2005 11:44am
nickp
Hi RRUK
Are they easy to fit ? Do you have to take the wheels off ??
Post #2457 Mon Sep 19 2005 11:58am
RRUK
I read the instructions manual on the Land Rover website and they seem pretty simple to do, there is no need to remove the wheels no.
I've heard they take about an hour to do them all if you take your time, it looks simple. Undo some screws/fasteners in the wheel arch area, put on mudlfaps and tighten fasteners. L319 D4 HSE
1982 Series 3 SWB
Post #2459 Mon Sep 19 2005 12:16pm
Bobby
nickp wrote:
Hi RRUK
nickp,
See my gallery for instructions.
Hope it'll help. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #2476 Tue Sep 20 2005 12:08am
Bobby
Hi nickp
Did the posting of the fitting instructions for the mudflaps help? Malaysia Boleh!
Post #2700 Tue Sep 27 2005 7:41am
nickp
Bobby
Thanks . In the end I got my dealer to fit them for a small charge , while my RRS was in having an arm rest changed because of a mark in the Leather.
Post #2702 Tue Sep 27 2005 8:24am
Bobby
nickp wrote:
Bobby
Oh .. OK.
Hope they solve your minor stonechip problems - if not, at least the car will look better now! Malaysia Boleh!
Post #2703 Tue Sep 27 2005 8:27am
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
I have installed front and rear mudflaps on my white HSE (see "before and after" pictures I just posted in the gallery).
As previously mentioned, installation is indeed quite simple and does take less than an hour, just follow the included instructions (which look like they came out of an Ikea furniture box...) The fronts are slightly more complicated to fit (you need to cut out a small section of molding around the wheel well with a blade), and for the rear a stubby Phillips screwdriver (or an offset / goose neck type) will greatly help in easily removing and replacing a couple of screws behind the wheels, since you cannot just steer them out of the way as you will do with the front ones.
After witnessing the dirty mess that one day of light Southern California rain left on the side of my car a few weeks back, I think the mudflaps will definitely help in keeping things clean in that area, while also protecting against stone chips. IMHO they look nice and incospicuous (on darker colors they should look almost stealthy) and are cheap enough, around $75/pair here in the US. Highly recommended.
Post #2843 Sun Oct 02 2005 5:04am
Bobby
Makes a great diference.
The car certainly looks much better. Malaysia Boleh!
Post #2844 Sun Oct 02 2005 7:49am
timajersey
Jersey 2005 Range Rover Sport TDV6 SE Cairns Blue
I had the mud flaps fitted by my dealer before it was delivered at the end of August.
When I cleaned the car yesterday I noticed that the screws used to fit the mud flaps were already starting to rust!
If I can't get any satisfaction at the dealer I will replace the screws with some of a higher quality or paint them matt black.
Has anyone else had this problem or got any good advice? RRS 2.7 TDV6 SE Cairns Blue/Alpaca Leather
'03 Porsche Boxster Seal Grey/Black Leather
Post #2845 Sun Oct 02 2005 9:55am
