Home > Technical > Oil leak from front of engine
Tomrogers
Is there any common places these leak from? (Tdv6) i took the inspection panel off near the front wheel arch and oil is dripping off the large pipe, jubilee clip was a bit loose so I nipped it up but I still get a drop appear in same place so I assume it's coming from higher up and d ripping down
I need to get it up on a ramp to have a proper look but thought I'd see if itw a common problem to give me a head start !
Thanks
Tom
Post #454708 Thu Mar 05 2015 7:26am
nigel52
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Had similar recently and was told it was a crankshaft seal leak. £2,500 later repaired by local stealer.
Post #454709 Thu Mar 05 2015 8:13am
flack
By the looks of that pipe I would put a new one on, also check the top end of the pipe and make sure plastic chamber is seated fully home and the big circlip is located fully in.
It could also be a pin hole in the inter cooler, but I would expect you to have seen errors if you had.
Flack Thumbs Up
Post #454710 Thu Mar 05 2015 8:16am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Seems like it could well be from front crankshaft oil seal. Have heard of quite a few of these leaks.Behind crankshaft pully. Have a look from top as well itisme
Post #454711 Thu Mar 05 2015 8:19am
Tomrogers
I'm assuming crankshaft seal is a huge job if he bill is £2500?
I'll take covers off top tonight and see what I can see, with regards to pin hole in cooler the car drives fantastic it's just annoying me having spots of oil on the drive
Post #454712 Thu Mar 05 2015 8:27am
harrygh60
I had an oil leak,drips from front of plate under engine. Indie repair £318. They did a smoke test,and said the oil was coming from a badly seated Y section of manifold between V section of engine. £2 fr a new seal and £90 for cleaning all oil away. and top up oil and new filter.The rest was for smoke test and labour. I was just pleased not to have oil leaks all over the drive way itisme
Post #454713 Thu Mar 05 2015 8:34am
Tomrogers
I'll have a proper look tonight from above once I take covers off fingers crossed it's a easy fix I can't be doing with a £1000 bill!
Post #454715 Thu Mar 05 2015 8:42am
Disco_Mikey
Crankshaft oil seal is about 4 hours work, and a £4 seal
However, from your photos, it looks like it is leaking past the hose clip. Try tightening it up first Thumbs Up
Post #454727 Thu Mar 05 2015 9:37am
Tomrogers
I was not very tight at all but I've tightened it and a drip still appears on the hose, what is this hose for?
Post #454728 Thu Mar 05 2015 9:40am
Disco_Mikey
Intercooler/turbo hose
Post #454749 Thu Mar 05 2015 2:49pm
nigel52
In the same situation again I would not go to a dealer but a good Indie who I revkon could have halved the price.
Post #454779 Thu Mar 05 2015 7:51pm
harrygh60
[quote="Disco_Mikey"]Crankshaft oil seal is about 4 hours work, and a £4 seal
However, from your photos, it looks like it is leaking past the hose clip. Try tightening it up first Thumbs Up[
So even at a main dealers prices it should only be around £550 to £600. I think Main Dealers will take you for a mug,if the opertunity arrises. £2500 Ouch Big Cry itisme
Post #454824 Fri Mar 06 2015 7:53am
Disco_Mikey
And a decent Indy would be able to more than half that again Thumbs Up
Post #454827 Fri Mar 06 2015 8:23am
