Home > Technical > Oil leak from front of engine |
nigel52 Member Since: 20 Nov 2013 Location: Farnham Posts: 274 |
Had similar recently and was told it was a crankshaft seal leak. £2,500 later repaired by local stealer. |
Thu Mar 05 2015 8:13am |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
By the looks of that pipe I would put a new one on, also check the top end of the pipe and make sure plastic chamber is seated fully home and the big circlip is located fully in.
Thu Mar 05 2015 8:16am |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
Seems like it could well be from front crankshaft oil seal. Have heard of quite a few of these leaks.Behind crankshaft pully. Have a look from top as well itisme |
Thu Mar 05 2015 8:19am |
Tomrogers Member Since: 12 Jan 2015 Location: Mk Posts: 18 |
I'm assuming crankshaft seal is a huge job if he bill is £2500?
Thu Mar 05 2015 8:27am |
I had an oil leak,drips from front of plate under engine. Indie repair £318. They did a smoke test,and said the oil was coming from a badly seated Y section of manifold between V section of engine. £2 fr a new seal and £90 for cleaning all oil away. and top up oil and new filter.The rest was for smoke test and labour. I was just pleased not to have oil leaks all over the drive way itisme |
Thu Mar 05 2015 8:34am |
I'll have a proper look tonight from above once I take covers off fingers crossed it's a easy fix I can't be doing with a £1000 bill! |
Thu Mar 05 2015 8:42am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Crankshaft oil seal is about 4 hours work, and a £4 seal
Thu Mar 05 2015 9:37am |
I was not very tight at all but I've tightened it and a drip still appears on the hose, what is this hose for? |
Thu Mar 05 2015 9:40am |
Intercooler/turbo hose |
Thu Mar 05 2015 2:49pm |
In the same situation again I would not go to a dealer but a good Indie who I revkon could have halved the price. |
Thu Mar 05 2015 7:51pm |
[quote="Disco_Mikey"]Crankshaft oil seal is about 4 hours work, and a £4 seal
Fri Mar 06 2015 7:53am |
And a decent Indy would be able to more than half that again |
Fri Mar 06 2015 8:23am |
