Home > In Car Electronics > Awesome android hack for existing screen
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
#t=98
Post #454430 Mon Mar 02 2015 8:43pm
Lost for Words
That's not a hack - just a GVIF interface such as this one: http://www.hids4u.co.uk/land-rover-discove...creen.html Thumbs Up
Once you have that, you can plug whatever you want in. Smile
It is possible to use the connectors on the back of the screen and access them via the hidden menu without a GVIF interface too. Wink Visiting from DISCO3.CO.UK
Post #454475 Tue Mar 03 2015 9:49am
zaphod
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
That sounds very interesting - do you have a link with more info on how to do this please? Could you hook up a reversing camera to it for instance? Smile
Post #454500 Tue Mar 03 2015 12:22pm
steve2026
2005 Range Rover Sport Supercharged Vesuvius Orange
If you tap on the link above it will answer your question. 2005 Vesuvius 1st edition ( now sadly gone ).
Post #454501 Tue Mar 03 2015 12:28pm
zaphod
Sorry, should have been more specific - I'm interested in knowing how to gain access to the inputs on the screen without having to purchase a GVIF Thumbs Up
Post #454502 Tue Mar 03 2015 12:31pm
Lost for Words
It's not really my area of expertise but I can explain a little.
Firstly, you need one of these - http://www.disco3.co.uk/shop/nav-screen-ca...e-p34.html This allows you to plug the camera (or another feed) into one of the ports on the back of the screen. I believe the middle plug is for the reversing camera.
With this, you can then access the feed from the hidden menu. The camera will not work automatically, yet. Unfortunately, while any of the inputs can be shown via the hidden menu, even if enabled, the DVD and TV buttons will not work without the DVD + RSE or TV systems fitted as applicable. Sad
To get the camera to work automatically, it will have to be enabled in the CCF and the screen put into Range Rover mode. This is done by cutting one of the wires connected to the screen to trick it into thinking it's a FFRR (the software is already there Wink ). You can install a switch which allows you to select the mode on start-up. More info here: http://www.disco3.co.uk/forum/topic74474.html Wink
As you will see, it brings with it several benefits but a diode also needs to be connected on the back of the screen or the brightness will be too low. Thumbs Up Visiting from DISCO3.CO.UK
Post #454512 Tue Mar 03 2015 1:49pm
zaphod
Thanks LfW - that looks like a brilliant weekend project for when the weather is warmer. Bow down
Not only could I get a reverse camera working but also access my phonebook, radio and other stuff on the screen. Sounds like a win win to me Thumbs Up
I get the impression that, by and large, the guys over on the disco forum are a bit more diy minded than the ones over here.
Post #454525 Tue Mar 03 2015 3:31pm
Lost for Words
Yes, we do tend to be a bit more hands-on. Underneath, the cars are the same but with the RRS having some more engines and options. Thumbs Up Visiting from DISCO3.CO.UK
Post #454530 Tue Mar 03 2015 3:51pm
