![]() | Home > General > Buying a 08 RRS HSE...Whatelse to look out for? |
Any links to the potential purchase |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
Sounds good 60k for that year, 2 owners and full service history. If your happy with all the history and test drive is ok but unsure about it leaning 2 one side park it up on a flat surface to be sure. If your also thinking of an inspection that can only be a good thing with reassurance.
RRSLover Member Since: 16 Jul 2013 Location: London Posts: 26 ![]() ![]() |
Thanks for the reply and yeah will park on a flat surface and see how it looks.
Here you go Peachy
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9045 ![]() ![]() ![]() |
but cheap Chinese tyres fitted. Hmm. Check that the tyres are the correct load rating for the RRS. Maybe use that as a price reduction issue if they're under spec. Seeing cheap tyres and expensive shiny bits always makes me wonder how much was spent on the oily bits. A "full service history" is just some stamps in a book and tells you nothing about what has been done to keep it in good order. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Good point. How would I know what the correct load rating would be?
Pretty sure the belts will need changing ths year - 105k miles or 7 years - this can be costly. Landrover did not do 22 alloys - those look like replica Kahns - check for cracks on the inside - I had 22's - 3 ended up with splits. The Hawke upgrades are to the individuals taste - but then create a smaller buyers market - lettering - vents - grill can be changed relatively cheap & easy if you got bored. I believe the TDV8 is well within your price range & I believe most forum diesel owners would choose this.
Min load rating is 106 on the 20 inch tyres. I would look for that as a minimum on those 22 inch tyres.
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 ![]() ![]() ![]() |
Looks like some 17 year old kid has got his hands on the ripspeed book from halfords. Messed about with cheap and nasty plastic bits and then brought himself some cheap ass tyres...
Indeed, spent thousands (according to him) but didn't get it colour coded. All sounds a bit wrong, doesn't it? £18k gets you a lot of RRS examples to choose from...
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
£67 2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Not sure that I would look any more at this one. Move on and find a nice one. If you can buy "in forum" it will probably have been loved and not chavved. |
http://www.autotrader.co.uk/classified/adv...?logcode=p
Nimbus Member Since: 01 Feb 2015 Location: London Posts: 14 ![]() ![]() |
I don't see the appeal of the first one, to each their own but I think it looks awful, the second one you linked looks a much nicer car. |
