Home > Technical > suspension light |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 |
Or alternator. I'm not Fat. RRS TDV6 HST. |
Fri Feb 20 2015 9:28pm |
ouchie Member Since: 09 Nov 2014 Location: ayrshire Posts: 20 |
when car was running a tested it was running over 13 volts so i ruled out altenator?? |
Fri Feb 20 2015 9:44pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
The TDV6 should be closer to 15volts |
Fri Feb 20 2015 9:49pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
A 100 mile drive won't recharge a flat RRS battery. What voltage do you see on the battery? You need to let the systems go back to sleep after you unlock and open the bonnet. 2012 SDV6 - it's missing a couple of cylinders
Fri Feb 20 2015 9:54pm |
I get 14.5 on tickover from the sat nav screen. I'd say you need to be nearer that figure. 13 sounds low possibly on the way out by sounds of it. I'm not Fat. RRS TDV6 HST. |
Fri Feb 20 2015 10:29pm |
ok thanks i will check the sat nav screen later also on the drive home after towing him out therevwas acwhining coming from the drivers side when u put your foot down ? altenator bearing on its way out ?? |
Sat Feb 21 2015 5:02am |
