![]() | Home > Technical > Cloudy Lens |
micalee Member Since: 24 Apr 2014 Location: Warwickshire s Posts: 241 ![]() ![]() ![]() |
I think I have found the issue with my dull len. http://www.rrsport.co.uk/forum/topic39157.html
sally Member Since: 01 Sep 2014 Location: out and about Posts: 376 ![]() ![]() |
If they get really bad it can fail the MOT due to poor light output but if you polish them now whilst they are only mildly cloudy you wont ever have to worry.
ian-r Member Since: 21 Jul 2014 Location: Nottingham Posts: 49 ![]() ![]() ![]() |
I had this on mine, was a good negotiating point on price |
Its not the outer lens, its the inner globe looking lens
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 ![]() ![]() ![]() |
I used toothpaste on my mrs old motor. Did the trick although try at your own risk |
The projector lens has gone cloudy on one side - how can I remove it or clean it? |
Richturbo Member Since: 07 Dec 2014 Location: Cheltenham Posts: 9 ![]() ![]() ![]() |
You would need to remove the main lense using a heat gun or oven method. Range Rover Sport Autobiography Dynamic 5.0 Supercharged
