Home > Technical > Cloudy Lens
micalee
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Cloudy Lens
I think I have found the issue with my dull len. http://www.rrsport.co.uk/forum/topic39157.html
It appears that the Xenon lens is cloudy, not alot but enough to notice. Am I amble to clean this and i presume it needs to be done on the inside?
Post #452696 Mon Feb 16 2015 12:41pm
Simon73
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
One of mines cloudy although doesn't seem to make much difference when driving around though plus just passed MOT fine just seems cosmetic really
Post #452707 Mon Feb 16 2015 4:01pm
sally
If they get really bad it can fail the MOT due to poor light output but if you polish them now whilst they are only mildly cloudy you wont ever have to worry.
They sell polishing compounds for headlights. Elbow grease needed unless you have a rotary in which case it will take 10 minutes! 2012 Evoque
2014 Sport Autobiography
2015 SVR for the fun stuff
2016 Evoque SI4 Dynamic Lux for the daily drive
2016 Defender 90
2018 SVR
Post #452712 Mon Feb 16 2015 4:44pm
ian-r
I had this on mine, was a good negotiating point on price Thumbs Up
I used wet and dry sand paper and then cutting compound to get them back good as new. Can upload photographs if required?
Post #452746 Mon Feb 16 2015 6:34pm
micalee
Its not the outer lens, its the inner globe looking lens
http://www.canadianautoreview.ca/images/ca...t-lens.JPG Not this one, but the equivalent on a 2007 spec!
Post #452751 Mon Feb 16 2015 7:06pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
I used toothpaste on my mrs old motor. Did the trick although try at your own risk Smile I'm not Fat. RRS TDV6 HST.
Post #452759 Mon Feb 16 2015 7:49pm
micalee
The projector lens has gone cloudy on one side - how can I remove it or clean it?
Post #458004 Thu Apr 02 2015 9:33am
Richturbo
United Kingdom 2013 Range Rover Sport Supercharged Izmir Blue
You would need to remove the main lense using a heat gun or oven method. Range Rover Sport Autobiography Dynamic 5.0 Supercharged
Range Rover Sport 4.2 Supercharged First Edition
Post #458127 Fri Apr 03 2015 1:55pm
