![]() | Home > General > Trailer damaged in collision |
Tony RRS Member Since: 19 Jan 2015 Location: Devon Posts: 18 ![]() ![]() ![]() |
here is a snap on the scene
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Yes a right mess.
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
While the car is on it's side, are there any maintenance jobs you could do? Clean brake pipes or check bushes etc? |
viper Member Since: 21 Apr 2007 Location: chester le street Posts: 857 ![]() ![]() ![]() |
Pleased your both ok |
ha ha, I had just dropped my Lamborghini Superleggera off at Pangbourne SDV6 HSE 2012 Black |
I did have a squint at the undercarriage and you will be pleased to hear that it was not damaged, until the boy at the yard pulled it out for me with a forklift ![]() |
A bloody Pug 206. No contest. SDV6 HSE 2012 Black |
I do not see the Pug on its side, its driver opened their door and stepped out, you had to climb out.
You should be able to turn the towing head/hitch 360 degrees. It is a piston after all. 2x TDV6. SE and HSE. Both returned to sender with issues👀
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 ![]() ![]() |
mine turns right round upside down |
And finally.
sally Member Since: 01 Sep 2014 Location: out and about Posts: 376 ![]() ![]() |
Glad you were not hurt and your trailer was empty. Destroying 2 cars in one go would send me over the edge.
I will stick with the RRS SDV6, just debating values with ins co.
