![]() | Home > Maintenance & Modifications > TDV8 TURBO REPLACEMENT! "DIY" |
Robbie Member Since: 12 Mar 2006 Location: Waiting for my old avatar to be allowed back... we miss her! Posts: 73 ![]() ![]() |
I'm just so envious of the 2-post.
austencameron Member Since: 11 Apr 2012 Location: Fife Posts: 41 ![]() ![]() ![]() |
very true! ![]() |
thankyou sir ![]() |
the pollys will keep it off the ramp longer! was fed up changing the lowers to often! ![]() |
thankyou sir ![]() ![]() |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Are the Pollys much of a job to change ?? I would of thought these would of been better ?? but there again i'm a locksmith |
Bit of a nightmare removing the old bushes from the wish bones due to seizure ! Plenty heat and a press was required. Bottom ones can be done with body on........top,ones on the other hand is a body off job as it was off anyway. Can be done with body on but its a real tight job and prey the bolts are not seized in the bushes! #grinder! The poly bushes being fitted is the easy part! I also done the anti roll bar bushes also as was so,easy with the body off. |
Neils RRS Member Since: 14 Oct 2014 Location: Aberdeen Posts: 47 ![]() ![]() |
Holy crap, top work fella! I dread to think how much that would be at the dealer! |
neils rrs, I seen afew old threads back in 2012 that the cost at a local stealership! was in the region off £9k!
Oh my god, that is criminal. |
