![]() | Home > Detailing & Car Cleaning > Polishing Piano Black trim. |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Got the same problem with mine, nightmare to keep clean as well |
MXSRR Member Since: 25 Aug 2013 Location: Lowestoft Posts: 228 ![]() ![]() ![]() |
T cut will remove the fine scratches, with a bit of elbow grease. MY2007 RRS TDV8 Black - tinted glass - side steps- stormer grille - 20" diamond cut alloys - alpaca leather - TV/DVD pack - some blingy chrome bits & bob's |
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 ![]() ![]() |
Thanks. I'll give that a try and use some of the black hole and report back. |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
I would definitely use a good but gentle polish but T cut is too abrasive in my opinion
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
Any good car polish will remove surface blemishes and fine scratches as its only the top coat (lacquer) which is scratched. As said above good elbow rub and you'll be fine. |
The more abrasive the polish the more lacquer it removes� depends on the severity of the swirls �
Saeedasghar Member Since: 11 Dec 2012 Location: Worcester Posts: 104 ![]() ![]() |
I would consider putting a glaze and coat of wax on first in case you could get away with that, as glaze has no cutting ability be safer on the panel. |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
I would have thought most polishes would make it worse as they would introduce more fine scratches and you can't break the polish down sufficiently by hand to get a decent finish. I'd try and glaze or sealant first too. FF 4.4 V8 Soooo looking forward to this bad boy
Superclean Member Since: 28 Sep 2012 Location: Berkshire Posts: 133 ![]() ![]() ![]() |
I tend to remove the piano blacks from the interior and correct them on the mini bigfoot. But black hole glaze will silicone filler the defects to a certain degree. Thus giving the appearance of a better surface finish.
Do not put T-cut any where near them |
Thanks all, black hole arrived the other day so will give it a go. |
