Home > Maintenance & Modifications > Suicide hesitation
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
30 minutes for just the blanking plates Gaz. Not majorly difficult. Plates are about £10 unless you want the full blanking kit for both ends which is about £30. I'm not Fat. RRS TDV6 HST.
Post #450501 Sat Jan 31 2015 9:06am
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
.....would I also be correct that if my 2.7 TDV6 is on an 07 plate, that fitting the blanking plates wouldn't throw up an ECU error???
Thanks,
Gaz.
Post #450502 Sat Jan 31 2015 9:08am
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Gaz I'm not sure 2007 onwards RRS can be blanked yet, as fitting the blanking plates will trigger the EML light. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #450503 Sat Jan 31 2015 9:09am
Gaz
Hmmmm.....Thanks Joe.
If I could get hold of some fitting instructions, it might be my next job!
I like to do my homework before tackling anything!!...lol
Post #450504 Sat Jan 31 2015 9:10am
Gaz
....ahh right.
I read from another source that after 2007 threw up an error but pre 2008 didn't.
Post #450505 Sat Jan 31 2015 9:13am
SRE
Spain
You need a good remap, changes the car completely.
Search on here and the Disco 3 forum for Pete Bells Remaps http://bellautoservices.co.uk/ In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #450509 Sat Jan 31 2015 9:57am
Gaz
There's a fairly sizeable old thread on this which I'm going through on here now....
One guy had an 08 plate done which has not thrown any EML errors.
His VIN was 8A.....mine is a 7A.....
Post #450511 Sat Jan 31 2015 10:09am
SRE
Spain
As I understand it some 07/08 MY cars may be running old historic engine software, hence they can get away with just blanking the EGR valves, however if your car is serviced properly then the dealer should have updated/flashed the ECU's to the latest level. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #450536 Sat Jan 31 2015 1:14pm
Gaz
I've only gone and found a specialist that offers a service of installing the blanking plates and carrying out a re-map to improve efficiency, power and tells the ECU to ignore the EGR data!!
Back of the net!!
Post #450565 Sat Jan 31 2015 4:28pm
SRE
Spain
Just be aware that EGR operation "may" become part of the MOT, hence why fitting emulators may be the preferred option. Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #450571 Sat Jan 31 2015 4:55pm
Gaz
Hi SRE!
The guys in depth explanation claims that there is no effect at MOT time.
Since then, I've spoken to another guy who offers this service.
He does it purely by remapping.
The EGR is programmed to stay shut as well as ignoring it along with usual benefits.
A boost from 188 BHP to 230 BHP.
I'm interested in getting mine done before anything fails!!!
Post #450575 Sat Jan 31 2015 5:13pm
SRE
Spain
Gaz
2017 It all changes - All emission systems (EGR, DPF, SCR, cDPF and such like) will be visually inspected for defects, missing & tampering. Checked for operation via OBD equipment, this is where emulators come in.
This year 2015 there will be a system that is web based, whereas, access will be available as to what your vehicle MY should be fitted with as standard, this info will be via the manufacturers data base. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #450587 Sat Jan 31 2015 5:54pm
SRE
Spain
Do a search on the Disco 3 Forum, there is bound to be some info about this on there. Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #450588 Sat Jan 31 2015 5:56pm
Gaz
.....wow.....that does throw a spanner in the works doesn't it.
Hell.....what do we do now?
How could an MOT station know a vehicle has been re-mapped if it met the emissions criteria?
Post #450604 Sat Jan 31 2015 7:51pm
FatJoe
Can't see MOT stations checking for EGR vavles. I'm not Fat. RRS TDV6 HST.
Post #450620 Sat Jan 31 2015 9:23pm
