Home > Maintenance & Modifications > Cheap engine oil ?
Royrw
United Kingdom 2009 Range Rover Sport TDV6 HST Santorini Black
Cheap engine oil ?
Hi Guys
Seen this in my local Asda is this any good for my 2.7 tdv6
Cheers Thumbs Up
 Range Rover Sport 2009 Stormer edition.
Post #448448 Wed Jan 14 2015 3:46pm
ABSport
Land Rover recommend Castrol Edge A5 5W-30 so seems similar Shocked
Post #448449 Wed Jan 14 2015 3:51pm
Royrw
Thanks ABSport not 100% sure as I checked the Castrol web site & it states
MAGNATEC 5W-30 A1
So is this better ok or worse/ not recommend? Range Rover Sport 2009 Stormer edition.
Post #448453 Wed Jan 14 2015 3:55pm
ABSport
Looks like you found a bargain as I went on Castrol website see link below Thumbs Up
http://oilselector.castrol.com/c/uk/eng/re...2009-2012)
Post #448455 Wed Jan 14 2015 4:18pm
Royrw
yes that's the A1 I mentioned but the Asda one is A5 ?? and just wanting a heads up on is it ok to do a full oil change with this stuff ? Range Rover Sport 2009 Stormer edition.
Post #448456 Wed Jan 14 2015 4:20pm
ABSport
Not sure what A1 and A5 are but someone will be along shortly. Personally I'd use it. Whistle
Post #448457 Wed Jan 14 2015 4:20pm
Royrw
I like your thinking Thumbs Up Range Rover Sport 2009 Stormer edition.
Post #448458 Wed Jan 14 2015 4:21pm
ABSport
I used Mobile 5w-30 that was in Halfords and in their guide. Done a full oil change and all is well. Thumbs Up
Post #448460 Wed Jan 14 2015 4:22pm
Paddi
You should look on the label for Ford Specification WSS-M2C913-C.
Don't think that is such a great price for only 4 litres. I just shopped around today and Halfords are cheapest - (last time it was ECP!)
I tend to use Mobil Super 3000x1 Formula FE 5W-30 and currently Halfrauds have it at £23.99 for 5 litres 2008 MY Java Black TDV8 HSE
Post #448461 Wed Jan 14 2015 4:29pm
Royrw
was it A1 or A5 ? Embarassed Range Rover Sport 2009 Stormer edition.
Post #448463 Wed Jan 14 2015 4:31pm
ABSport
That's what I used Paddi just got a genuine oil filter and replaced oil with Mobile 5w-30 from Halfrauds Rolling with laughter easy job Thumbs Up
Post #448464 Wed Jan 14 2015 4:31pm
ABSport
I don't think it matters Very Happy
Post #448465 Wed Jan 14 2015 4:33pm
Paddi
Mobil Super 3000x1 Formula FE 5W-30 also conforms to ACEA A5/B5.
If you go by the Ford specification (recommended by LR) it might be best if you ever have a warranty claim as it is one less way for the warranty company to wriggle out of covering you Rolling Eyes
And yes - absolutely only use genuine LR oil filter or you are asking for trouble (they are only a tenner). 2008 MY Java Black TDV8 HSE
Post #448466 Wed Jan 14 2015 4:37pm
ABSport
Post #448467 Wed Jan 14 2015 4:46pm
Royrw
Cheers Thumbs Up Range Rover Sport 2009 Stormer edition.
Post #448469 Wed Jan 14 2015 4:51pm
