Home > General > Many Faults!!
road2ruin
United Kingdom 2009 Range Rover Sport TDV8 HSE Java Black
Many Faults!!
Merry Christmas all, hope everyone has had a good one. I have just arrived home having spent it down on the coast with the folks and all was going fine until we got 20 minutes from home and the dashboard light up like the proverbial Christmas tree!!
The warning lights were:
Brake Systems
Suspension Systems
Dynamic Stability Control
We also had the following error messages flash up:
Parking Brake Fault
HDC Not Working
Suspension Lowered
Transmission Fault
I have had a quick Google and have check brake lights (working) so I’m hoping it’s just the battery that might be playing up however before I end up in the garage has anyone else had this situation just so I can be prepared?!
Post #446585 Sun Dec 28 2014 4:58pm
dazzerboy
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
yes had the lights up was the alternator and I changed the battery as well Smile
Post #446589 Sun Dec 28 2014 5:10pm
V8SC
2006 Range Rover Sport Supercharged Bonatti Grey
I think the brake light switch is a common fault that has also been known to cause these warnings...a fairly cheap and simple fix I believe. Carl
Post #446611 Sun Dec 28 2014 8:54pm
aljo
Have you had the fault codes read ?
If not and your near enough to windsor /ascot I could read them for you Thumbs Up
Post #446617 Sun Dec 28 2014 11:47pm
D12TYJ
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
Sounds more like the alternators over charging, check the volts on it, could even be a brake light switch.
Could even be something totally different.
Post #446623 Mon Dec 29 2014 1:26am
simple1
Have you changed a brake bulb recently? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #446636 Mon Dec 29 2014 8:52am
