Home > Faults & Fixes > Need help |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8986 |
Have a look here: http://www.rrsport.co.uk/forum/topic20468....ood+switch 2012 SDV6 - it's missing a couple of cylinders
Sat Dec 27 2014 5:54pm |
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 |
I had this problem recently, sprayed the alarm switch all over with WD40, and that sorted it! |
Sat Dec 27 2014 5:56pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4402 |
My switch failed, so was shorted out with a split pin. Then my split pin started playing up, so the connector was cut off, and the wires soldered together |
Sat Dec 27 2014 6:07pm |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
I unplugged the switch and back in and it seems to have worked will have a better look in the morning |
Sat Dec 27 2014 6:29pm |
rudadu Member Since: 12 Sep 2014 Location: Dunfermline, Fife Posts: 48 |
I had the same problem. Cleaning the gunk from the switch helped for a wee while but problem eventually returned. I disconnected switch and did similar bypass as described by Disco_Mikey with a small piece of wire until I bought a new switch. £10 or £12 I think it was. The switch itself is really easy to replace in a few minutes. 2016 L494 SDV6 HSE Dynamic Carpathian Grey |
Sun Dec 28 2014 9:32pm |
I've ordered the new switch anyway so will change it but thanks coral the info guys |
Mon Dec 29 2014 3:39am |
