![]() | Home > Faults & Fixes > Need help |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 ![]() ![]() ![]() |
Have a look here: http://www.rrsport.co.uk/forum/topic20468....ood+switch 2012 SDV6 - it's missing a couple of cylinders
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
I had this problem recently, sprayed the alarm switch all over with WD40, and that sorted it! |
My switch failed, so was shorted out with a split pin. Then my split pin started playing up, so the connector was cut off, and the wires soldered together |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 ![]() ![]() ![]() |
I unplugged the switch and back in and it seems to have worked will have a better look in the morning |
rudadu Member Since: 12 Sep 2014 Location: Dunfermline, Fife Posts: 48 ![]() ![]() |
I had the same problem. Cleaning the gunk from the switch helped for a wee while but problem eventually returned. I disconnected switch and did similar bypass as described by Disco_Mikey with a small piece of wire until I bought a new switch. £10 or £12 I think it was. The switch itself is really easy to replace in a few minutes. 2016 L494 SDV6 HSE Dynamic Carpathian Grey |
I've ordered the new switch anyway so will change it but thanks coral the info guys |
