Home > Technical > RE: Heater problems |
KiwiCool Member Since: 25 Sep 2006 Location: Hanmer Springs, New Zealand Posts: 71 |
Question ? this weekend now it only giving off cold heat. What is cold heat please ? SDV6 (14.5) Corris Grey NZ Spec + door mouldings, mud flaps and tow bar
Mon Dec 22 2014 2:44am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Check coolant level, might have an air lock in the system 2008 G4 RRSport TDV8 current
Mon Dec 22 2014 10:26am |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
I have the same problem, the result being that it often blows hot when I want cold and visa versa. I took it to the dealers that said that there was a software update to fix this. It didn't fix it so I need to go back to them again, not going to be this year though due to Santa coming. |
Mon Dec 22 2014 10:39am |
EDIT - was replying to the wrong thread! Bodsys Brake Bible
Mon Dec 22 2014 10:52am |
EDIT - Was replying to the wrong thread! Bodsys Brake Bible
Mon Dec 22 2014 10:53am |
Nav01 Member Since: 18 Jan 2013 Location: North London Posts: 99 |
@ KiwiCool sorry meant it only blows cold air now.
Mon Dec 22 2014 3:19pm |
@Camelrock surely they should have checked the coolant level when they carried out the service. |
Mon Dec 22 2014 3:22pm |
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 |
Any update, how'd you get on with the heater problem? Mine seems to have developed the same fault. |
Mon Feb 22 2016 9:16pm |
MOB4LIFE Member Since: 23 Mar 2015 Location: London Posts: 17 |
Check your heater controller could be faulty - i had the same problem years ago. RRS 3.0 AUTOBIOGRAPHY DYNAMIC 2016
Fri May 20 2016 2:48pm |
